KLZE AC Compressor
KLZE AC Compressor
Would anyone know if AC compressor for KLZE is a direct replacement of AC compressor for V6 1.8 liter engine? Any help is greatly appreciated. Thanks.
- papa roached
why not just use your 1.8 one, it bolts up to teh block
