Question about Transmissions With KLZE
hello everyone,
im just curious about the KLZE swap. i love the idea of all that power, but im just wondering, alot of ppl simply just roast there tires in first gear... and have pretty high RPM on the highway.
I know how transmissions work, however, i dont know what exactly a final drive ratio or gear ratio is. but i was wondering if there were any alternitives to the MX-3's Trannie, the Mx-6's has a final drive ratio i believe... but what exactly does that mean? more play in each gear? a lower rpm on the highway?
im not a huge drag person, so i would like a trannie that feels rightly placed with the ZE, not just a really really short 1.
didn't the car that the ZE originally came in have a manual trannie? how come no one ever puts those in?
hope u guys can answer my questions and thanx for reading.
Peace
Peace
hgallegos915
i had heard the mx6 tranny goes to 140.. aka longer gear. Basically thats it. People either use that or the k8. k8 is shorter gear
-hec
Juans_93_MX3
The final drive on the probe/mx3 is 4.39 and on the mx6/626 is 4.11
If your worried about highway driving and roasting your tires, go with the MX6/626 trannys
EDIT: Infact, even for racing the MX6 and 626 trannys are the best
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- jschrauwen
By the sounds of it, your trying to do your research and have stumbled upon a commonality. I believe the the 626/MX6 would give you a more appropriate gearing than the MX3. Your probably in the over 30 crowd so smoking the tires isn't really your thing, me neither. I've been giving that some consideration for next winters project. The MX3's TX is geared a liitle too short and I too would like to see lower rpms at highway speeds. I've seen that somewhere (Georgia) I believe that there's a place to source JDM TX's that come with limited slip. I'm going to get more into it this fall. I think the use of the MX3 TX was simply cost savings and conveniance.Damious wrote:alright thanx, i think i will. i still haven't quite figured out the reasoning of ratio's but thats ok....
is that 140 MPH? cus thats alot faster then i plan on going anyways...
Gro Harlem
definitely go with the 4.11 final drive, it is better suited for the ZE.
I firmly believe it is better for accel in the 1/4 as wel since it keeps the car in its powerband longer
DONATE TO MX-3.COM
DONATE TO MX-3.COM
great to hear. i suppose ill be planning on that tranny when i get the ZE. mind as well get it all over with in 1 big smack right?
r there any codes on it that differ from the Mx-3's that i should know about? i would hate to spend money just to get the exact same transmission
oh and by the way, thanx but im only 19...
- hppwdn
MX6 transmission all the way. I was very pleased when I put one in my probe and I think I've got one lined up to put on my MX3 this weekend. The longer first gear is great when you have that extra power.
