We got tired of playing with the all motor BP setup. The car is running pretty good, smacking local Hondas left and right running all motor. We decided that it's time stop advancing the timing (setting at 26* advance currently) and give the turbo Hondas a hidden dose of their own medicine. We're keeping it sleeperfied for the moment.
We fabed up a short runner manifold (my left over manifold pieces), picked up the slightly used 16G turbo from my brother's Talon (I'm rebuilding it with a GT32 turbo, oversized valves, blah blah blah), jacked the side mount IC and BLOV off of it while we were at it, and I donated my old RC Eng 440cc injectors. The car already has a Wahlbro 255 pump in it, Jacobs Ignition, Magnacore KV85 Plug Wires, SPEC light weight flywheel, ACT racing clutch, and massive weight reduction.
The side mount intercooler is going in front of the driver side wheel well, it required a little more weight reduction to make it fit
. We're even using the stock DSM IC hoses (for now).
Here are some pics of the turbo manifold with the 16G just bolted to it (those are the stock DSM Oil and Water lines still on it). We'll keep posting updates...soon to include time slips, etc...
