I have a stock 1994 GS with about 90800 miles and original everything almost. This is my first car and i never really learned how to drive a stick, i just sorta taught myself, so i just had some questions about what is normal.
I know my clutch is slipping in almost every gear, it doesnt shift as smoothly as it used to and it does the weird rpm thing. I'm going to take it in to get done 'professionally' but i wanna wait till i have enough money so.. here are my stupid questions:
1) how much does it cost on average? I know they charge for their time and it depends on what parts they need to fix, but what price range should i expect? (I dont want anything fancy since i dont know how long this car is gonna last.)
2) when the clutch is slipping do they only need to replace the clutch plate or the whole system?
3) with the new clutch, will the pedal feel more stiff than the old one?
4) is it normal to be able to shift through all the gears without using the clutch when the car is off?
and i also had a question about my timing belt. it has been worn out for a long time but i have been putting off replacing it. does the timing belt have anything to do with why my steering is so loose? or is that a totally different problem?
one last question, any ideas about what the sucking noise is when i am coasting? i cant tell where it is coming from exactly but it usually doesnt happen when i accelerate, or i just cant hear it.
A few questions about my clutch...
- neutral
I gotta run so will make this quick. my .02. Your clutch Q's answered on this other thread http://www.mx-3.com/phpbb2/viewtopic.ph ... highlight=
Your timing belt has no effect on steering, ever.
Hafta hear the sucking noise to really ID it.
Sure others here will have their .02 with more info. cya and g'luck
-Jimwell... it would be best to replace everything
they come in kits usually anyways, and would be less of a hassle if you fix it and then another part of the clutch goes
they're about $250 canadian with tax
as far as labour cost goes... depends on the mechanic you go to.
it'll range from $50 to $150
performance clutch kits will run you about $350 to $450 canadian (depending on what kit and its features are)
Timing belt is just as important as a clutch. If that breaks you risk bending valves (blowing motor). The clutch requires engine and transmission to be seperated but it is possible the clutch is just not adjusted right (the mx-3's do have adjustable clutch right??) I would bite the bullet and have it all done, seeing as you still have a pretty good car. I would say get them both done for $600 plus the cost of the clutch..which really isnt all that bad.
94' MX3 GS atx
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
2000 kawasaki kx 500 MX
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
- Ricksmx3
Where are you located? Cause i went to Advanced Auto Parts and got me a whole clutch set for $140 (nothing special just a regular clutch). Then the labor was like $250 or something. So all together it was almost $400. And when i got my clutch replaced the pedal was so much easier to push in and shifted so much smoother.
2010 MazdaSpeed 3
thanks for the replys
im in michigan
ive been going to a local auto place for all my exaust problems and they said for the timing belt it would cost about $650 and i dont wanna spend that much so i have been looking around. I want to find a place that will do the clutch and the timing belt at once but no where around here does both engine and trans stuff.
im in michigan
- papa roached
to bad when the timing belt breaks on this motor you dont bend valves, its a noninterference motorMX-SLICK wrote:Timing belt is just as important as a clutch. If that breaks you risk bending valves (blowing motor). The clutch requires engine and transmission to be seperated but it is possible the clutch is just not adjusted right (the mx-3's do have adjustable clutch right??) I would bite the bullet and have it all done, seeing as you still have a pretty good car. I would say get them both done for $600 plus the cost of the clutch..which really isnt all that bad.
Keira wrote:thanks for the replys
im in michigan
$650 for the timing belt... holly crap thats a lot of ripping off
theres a clear indication to STAY AWAY from that place.
they're simply milking you.
