Tires
Tires
ok I just did the BP swap... now im still using the honeycombers (Iknow sad) but i noticed my tires squeel when taking turns even at low speeds is that tire inflation or is my alignment out... keep in mind the suspension was not touched right now my tires are at 35 psi on the front 32 on the rear.
Management is not responsible for lost or stolen virginities.
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
- Tunes67
If your tires are squealing during low speed turns it could very well be your alignment. I dont think the swap would affect the Toe part of the alignment.. but if the engine/trans is heavier.. it could affect the Camber (or may I have that reversed.. I always get them mixed up LOL)
Center your steering wheel straight forward and then look at your wheels.. are they both pointed straight forward? They should look like this (From a top view)
Now if they look like one of the following.. definately get it aligned.
| / or \ | or the worst \ / This last one usually happens if the center link goes bad. Hope this helps.
Tunes67
Tunes67
- Tunes67
Thats not good either.. figures you would find it to be the one combination that I didnt put up LOL Anything other than | | requires an alignment.
Tunes67
Tunes67
it would seem i have a negative camber problem... i did replace the lower ball joints and the driveshafts.. so i guess an alignment is what i need. however after reading the proceedure for adjusting camber.. is there any way to do this myself possibly with a laser lever?
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
- Tunes67
Not that I am aware of.. however.. if you want to be able to do you own alignments, not a bad idea by any means especially if you plan to do different suspension setups for racing and such, you can always check into getting something like this
http://www.harborfreight.com/cpi/ctaf/D ... mber=92749
Though you will probably find these a bit more affordable
http://www.harborfreight.com/cpi/ctaf/D ... mber=45742
Hope this helps
Tunes67
Hope this helps
Tunes67
