Ok need to know from the experienced boosters of v6s
i currently am running the ze
the t3/04e what rpm range would boost kick in approximatly?
and the t3(same question)
im guessing around 2700rpm for the t3 and closer to 3500 for the t3/04
are my estimates correct?
Boost kicks in @.....
- babyblueMX3
right now full boost at 3.5k @ 5psi w/out filter VAF between turbo and intake
running t3-t04e 57 trim
0.83 a/r on the hot side and 0.50 on the cold side
when the boost kicks in damn it pulls hard
RIP 400whp ZE-T MX-3
Juans_93_MX3
- Nomad_69er
