Klze Engine Serial #
- shawno
I have a klze or i hope it is a klze, but i reason to belive that it is a KLde but i was wondering if anyone can tell or read the engine serial number or even give me a web site that can tell me what it is like year and if it is really a klze motor
Serial # KL 693663
Serial # KL 693663
serial ID's the block...i don't believe it is possible to ID a KLZE vs. KLDE using those numbers
DONATE TO MX-3.COM
DONATE TO MX-3.COM
for the love of god! NO
square ports came on USDM KLDE's too! that is NOT A WAY TO ID the engine as a klze.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
COMPRESSION TEST IT...... I thought mine was a regular millenia engine but than my compression test showed around 210 psi dry on all cylinders and I have KL-101 heads. But my engine is insane so go figure.
92 GS, 210 psi per cylinder KL-101 Engine, Pacesetter Exhaust, Centerforce DF, CAI, Hi Flow Cat, Headers.
By Spring 06: Megasquirt and FPR
By Fall 06: KL-31 Heads with Interprep Cams
