Hmm Shifter Problem
Zbroja
Hmm Shifter Problem
Post by Zbroja »
Heya guys.
I've got a problem with my shifter. Anywayz here is the story:
I was driving down casually from the store after I picked up some milk for my mom, and all of a sudden my shifter (The rod and the whole thing) Just drops a few inches and starts to bounce up and down when i hit bumps in the roads. I can still shift properly and everything but its not right. So I drove home thinking that maybe the screw that holds the whole thing from under the car just came off. Anywayz I jack the car up and check it out, seems that the mx-3 doesn't hold the shifter in place by a screw but instead by a piece of plastic off the side which just shoves right in. I found that odd, so I pushed the shifter back in with my hands and it stayed there firmly. I take the car for a spin and everything is fine until I hit a speed-bump or something bumpy for that matter. It falls out and begins to bounce again (The whole shifter drops about 3-5 inches) . So I drive home again and hoist the car up again. This time I check it out throughoutly and it seems that piece of rubber that holds the whole shifter in is basically falling apart. Anywayz my question to you guys is how I can fix this without it ever popping out again? Can I get another piece of rubber like that or maybe I should hammer it back in???
Any thoughts? Help is direly needed...
Thx all!
mx almere
Post by mx almere »
bmwm3guy
Post by bmwm3guy »
shouldn't there be 4 bolts holding it to the body of the car???
Chasing_Size
Post by Chasing_Size »
There are two plastic clips, that eventually break on our cars, it holds the shifter linkage to the car, the reason why it broke is because the " stabilizer " bar attattched to the bottom of the shifter, then again to the tranny, came loose....
Go underneath your car, and drill a hole into the bottom round thing undrneath the shifter, intot he body of the car, secure it with a bolt, this will solve the problem.
1992 Mazda mx3 gs / 03 / ms8 intake manifold / klze 67mm bored TB/ Custom CAI / 2.5 Custom exhaust / Drift kit front and sides/ CF Invader hood / 17'' MSR gunmetals with chrome lip / Tockico Blues / Suspension technique springs / Leather interrior/ B&M SS / Fully customized interrior (Red and black) / Corvette Red 00 Paint w/ white,blue,gold pearl / Shaved altezzas w/ black trim/ Front rear strut bars / ze ecu ( I think that's all )
