Alternatives to Haltek
- Cpl_Bryant
My BPT did not come with an ECU. I am trying to save money by not going with a Haltek. I think it is just too much for what I am trying to do. I need something a lot cheaper than $1,400+. What are my options?
- atlantamx3
- Cpl_Bryant
- BuGS
Well I think if you had the time to learn the system or the help the Greddy Emanage is a really great system. For a piggyback with a piggy back price it does a lot. Fuel maps, timing, and even has an optional Map sensor for when your MAF scale is maxed out. It just takes some time to learn how to tune, I don't have time thus I went with a SAFC II for my turbo project. Also, there is a custom AFC that a guy on clubprotege.com is making. go to the turbo section there to get more info.
AEMs new system is like 800-900 bucks
second hand haltechs are around 600-700
megasquirt is only like 300 max
motec not an option cause its like double what you want
wolf 3d is an option
sds is an option as well
- Custommx3
- Site Administrator
precisionracingonline.com sells the megasquirts, thats what Im getting.
But if your up for it you can build your own.
http://www.megasquirt.info
- ryanlindenberg
CARDOMAIN WITH UPDATED PICS
Good deal for a Haltech!ryanlindenberg wrote:http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
![Image](http://img.photobucket.com/albums/v641/blackmarket/sigpicmx3-1-1.jpg)
e6k is the older model, the new release is e6x. You can get the new model93SOHC wrote:Good deal for a Haltech!ryanlindenberg wrote:http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
around 900, forget about the old one.
- ryanlindenberg
yea i got my e6x off ebay for 900 with a 3 bar MAP.
i started putting in my BPT today. so far so good...the turbo motor is in, just need to connect hoses and do a little bit of wiring and i should be good to go. hopefully i will be done tommorow.
