To anybody with a set of headers!!!
Posted: May 9th, 2005, 7:23 pm
by mazdubber
I'm trying to find a bolt to plug the EGR on the OBX headers. I'm pretty sure it's an M22 fine thread. Now I've been absolutely everywhere and can't find this ultra rare bolt! Where did you guys get yours from???
Posted: May 9th, 2005, 7:38 pm
by lucky13
I think people just leave it unpluged, but I am not sure.
Posted: May 9th, 2005, 8:13 pm
by bmwm3guy
lucky13 wrote: I think people just leave it unpluged, but I am not sure.
ummm no.. leaving it unplugged would be a bad idea. You need to plug it somehow. I was also looking for this plug.
Posted: May 9th, 2005, 8:34 pm
by quicksliver
Yah DO NOT leave it unpluged lmao, bad idea.
Posted: May 9th, 2005, 9:55 pm
by mazdubber
Yeah, I know it has to be plugged. But I can't find the bolt anywhere!!! I'll try a few more industrial supply places tomorrow I guess. This is a real PITA!!!
Posted: May 9th, 2005, 10:10 pm
by mx3-ze
I went to a local ma and pa hardware store with the egr fitting I cut off my car. It matched up with a threaded plug with an allen socket in the back of it. Put some copper rtv on it and it screwed right in. Hardest part was getting a decent turn on the allen wrench due to tight space. Seemed to be a regular pipe thread. Hope this helps
Posted: May 9th, 2005, 10:51 pm
by MX-3 Money
well if you don't need the egr anymore, why not cut off the end part with the threads and just weld the little hole shut. Or just fill the threaded hole with a weld?
Posted: May 10th, 2005, 1:45 am
by Rick Johnson
Yea I would just take the old EGR piece with threads and weld it shut then put it back on.
Posted: May 10th, 2005, 5:43 am
by jschrauwen
mx3-ze wrote:I went to a local ma and pa hardware store with the egr fitting I cut off my car. It matched up with a threaded plug with an allen socket in the back of it. Put some copper rtv on it and it screwed right in. Hardest part was getting a decent turn on the allen wrench due to tight space. Seemed to be a regular pipe thread. Hope this helps
If it's a regular pipe thread than finding a suitable plug should be fairly easy. Pipe threads only come in a certain amount of sizes. The transmission fill and drain plug use a 23mm sized head - don't recall it being a fine thread pattern though.
Posted: May 10th, 2005, 8:34 am
by ccreech
Yep...I cut the fitting off of the pipe that came with my headers...and got them to weld it shut when they did my muffler
Posted: May 10th, 2005, 9:10 am
by Gro Harlem
take the egr pipe they give you, crush one end of it so yo ucan remove one of those threaded nut thingys. Then have the exhaust shop weld the nut thingy shut.
thats waht i did at least....that way i can remove the plug if i ever resell the headers to someone who has EGR.
