94-98 Swap question
Posted: May 8th, 2005, 2:19 pm
by projectmx
Has anyone with the 94-98 mx-3 dohc successfully done a bp / bpt swap yet? i'm very curious about the dificulty level and what all is needed for it cause i'm thinking about attempting this but i know it is supposedly harder to do this for the 94 and newer models than the older ones.
I am shooting for 180 - 200 hp with and still have a very reliable and long lasting car and engine. some day i may go higher but right now that is all i want.
Posted: May 8th, 2005, 8:56 pm
by Flashpoint2
I was actually wondering the same thing, and i did a bit of research. In my case anyway, its cheaper for me to just turbo the 1.6l. Mind you, I only want to get about 160whp.
Posted: May 11th, 2005, 2:25 am
by Devilhog
I was also thinking about swaping but thought it would be a bit to much of a hassle since im not exactly equiped to do it
Is there any faq's or guides on turbo'ing a 1.6L Dohc?
Had my 96 rs for just over 4 years now, its been alot of fun stock but I want to start personalizing it and adding some "zoom zoom" to er
Thx
Posted: May 12th, 2005, 10:52 pm
by David Witherow
ive done it.......first i had it swapped in place in my 92 SOHC....and now in my 94 DOHC not to many problems very easy and i even used a newer gen BP.......ie from a 97 protege.....the only problem im having is that it is a little weak on power but i know there are a few other ppl with it done
Posted: May 14th, 2005, 5:55 pm
by rsroadkilla
any1 got any info about the bolt on turbo kits for the dohc???
ie, where i can get one from, a rough price, estimated power putput, what boost i can run it at???
Any info will be awarded with jaffa cakes and glasses of ribena toothkind!!!
Posted: May 15th, 2005, 1:08 am
by ertaisi
There are no bolt-on kits for our cars, unless you count the stock 323 GTX turbos and such. There's some for the Miata B6 engine, but apparently the piping is different so we can't use it.
Posted: May 15th, 2005, 1:27 am
by rsroadkilla
ah right. Right pain in the arse then!!!!
