which zex kit?
which zex kit?
what zex kit should i buy for my bp? part number? i also want the wet kit. i need to be faster than 16.1!!!!!!!!!!!
bp mx-3
Rick Johnson
I have the Zex dry kit #82011 if you want the wet, which is IMO is better, the part number is #82021, the only reason I have a dry is cause I got a smoking deal on it. The dry kit does compensate for fuel a little bit by tying into your FPR, so it works a little better then just a straight dry shot.
- Flashpoint2
