Vacuum Leak?
Talon_66
Vacuum Leak?
Post by Talon_66 »
So I thought I had all lines plugged into there proper locations. This one may have come off. But can someone please tell me where it goes, just 2 be sure?
http://xs.to/xs.php?h=xs26&d=05170&f=vacuumleak.jpg
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
babyblueMX3
Post by babyblueMX3 »
did you try to locate it with the vacuum diagram ?
judging from the length it ooks like it's suppose to connect to the egr valve behind the intake but I'm not sure on this one. Is the solenoid that the vacuum is coming from is attach to a bracket with 2 solenoids right one beside the other ?
RIP 400whp ZE-T MX-3
Talon_66
Post by Talon_66 »
I checked the ZE vacuum diagram I am just not sure if this is the Solenoid, and this is the line that is supposed to go to the 'air cleaner'
Here is another pic
http://xs.to/xs.php?h=xs26&d=05170&f=Vacuumleak2.jpg
babyblueMX3
pic not working
try to write URL instead of IMG next time it'll give us the link automatically
Talon_66
Post by Talon_66 »
babyblueMX3 wrote:pic not working
corrected
Talon_66
Post by Talon_66 »
Anyone?[/list]
faried
Post by faried »
Purge control solenoid. One hose connects to the black cannister and the other to the bottom of the TB.
Talon_66
Post by Talon_66 »
Thanks to BabyblueMX3. He helped me diagnose the problem over MSN. Thanks again.
The problem was EGR. I have since removed all EGR from my car.
babyblueMX3
good to know things are alright now :)
