Clutch Pedal stuck on the floor
Posted: April 30th, 2005, 1:25 am
by nolig2278
twice this week my clutch pedal got stuck to the floor.
fluid level is where it should be.
thoughts?
Posted: April 30th, 2005, 3:09 am
by ryanlindenberg
don't really know, but it happened on my mom's 626 a couple years ago...it eventually just went away and hasn't happened for a long time now. wierd....
Posted: April 30th, 2005, 7:30 am
by neutral
Ck out pages H-4 (clutch troubleshooting), H-6 & H-7 (diagrams) of the online manual - link is on the MX-3.com homepage. Inspect the pedal assembly just underneath the pedal hinge/pivot point where there is a pushrod extending toward the firewall. Make sure the pushrod has free movement with no binding when pedal is depressed & released. On pg H-4 troubleshooting table, Mazda refers to it as the "pedal shaft" but the diagram label for the same part on H-7 appears to be "pushrod."
Posted: April 30th, 2005, 7:37 am
by Grants
Ya or your clutch is f***ed right out. Hanging in on sympathy... Maybe you know more than your saying? You done nothing different? No point when it started?
Posted: April 30th, 2005, 5:27 pm
by nolig2278
The clutch is not old, not that that matters since i busted a fork 6 months after bpt install. But i had this one put in by 'pros'. My engine head seems to have shift, and my brake pads are a little low but that is all i think is wrong with the car right now. If this is just a fluke then great. O and i did replace master cylinder a couple yrs ago.
Posted: April 30th, 2005, 11:29 pm
by 92rsmx-3
try bleeding it.
