dohc turbo idle issue..possible solution?
facko
Post by facko »
hey i had asked earlier about an idle problem i was having with my dohc 1.6 after turboing it and i found out it was most likely my BOV leaking air, but i got a new adjustable one (turboxs type-S) and it isnt leaking anymore, but it still doesnt like to idle till its warmed up. I was thinking about what the problem might be an i came up with a possible cause...the 323 header i got is cracked in the normal spot down the middle and the crack goes right to the o2 sensor...could the crack be giving the sensor a bad reading until it heats up and closes? or any other suggestions on this would be appreicated too. thx guys :D
BP swap -- Pacesetter Header -- Custom CAI -- Custom 2.5 Exhaust w/ a Thrush Glasspack and 40 Series Flowmaster -- SPEC Stage 2 Clutch Kit
Tunes67
Post by Tunes67 »
Might check the Idle Bypass assembly (Bolted to the bottom of the throttle body) its also where the IAC attaches to the TB. You will need a new seal if you crack it open to clean it out. The seals are available at the mazda dealers.. $18 US. Since there are two coolant lines that attach to the bottom of the throttle body (the idle bypass assembly) and Since your idle problem is happening only when the engine is cold.. I would guess this needs to be cleaned up. Hope this helps.
Tunes67
freyguy_412
Post by freyguy_412 »
You got cams? My boys honda SOHC idles like a pos when he starts it cold b/c of that cam and timing combo... but its fast though.
It might be slow, but it's not a civic!
facko
Post by facko »
nah stock cams the only mods are the turbo and bigger injectors (bp). ill try out the idle bypass assembly thing tho, i just gotta buy a seal offline or somethin cuz we done have a mazda dealer in town =(. thx for the replys tho!
Return to “Forced Induction”
