Performance upgrades...
Awhe
Post by Awhe »
I have a 1.6 L 4 cyl automatic and am looking to do something to the motor to get a little more out of it... is there really anything besides swapping the motor?
clay
Post by clay »
i just took off my stock intake and put on a cone filter driectly on my mass air flow secor...seemed to help a bit...not much tho
http://www.etuner.ca
Exec etuner member
Awhe
Post by Awhe »
you gonna put the whole intake kit on?
monty73741
Post by monty73741 »
oh kay there are tons of diy intakes on the web
get a custom cat-back
prem pugs & wires
Jason Danaher
Please Help Support MX-3.com
clay
Post by clay »
im getting a pipe bent, but im away for school so my machenic is about 250km away, so it be a couple of months befroe i do.
Exec etuner member
jdmtim
Post by jdmtim »
theres nothing u can really do to those motors i had rx7 maf exhaust and intake 5spd only made 87 hp :cry: just think about that in a auto
Post by wytbishop »
There are literally a thousand things you could do...
Port the head
Polish the head
Port match the exhaust manifold
Bigger cams (from a Miata)
Bigger throttle body
Bore the throttle body or replace with a larger one
Higher compression ratio pistons
Lighter flywheel
Underdrive pulleys
...just off the top of my head.
Search the BB and you will find millions of things. Guys are getting 150+ HP normally asperated all over the place.
monty73741
the miata cams will only work on the DOHC
Bigg E
Post by Bigg E »
will they need any major custom work to put them on the DOHC 1.6
1995 MX-3 RS: ST lowering springs, Front & Rear Strut Bars, 95 GS spoiler, ACT Stage 1 Cltuch kit, B&M Short Throw, Corksport braided steal clutch line, Corksport bronze oil bushings, 17 inch BSA rims, Tint, Chrome Altezza's
Pics http://www.cardomain.com/ride/537422/1
Post by wytbishop »
There are no modifications as far as I know but it is not a straight swap. The drive for the distributor is diffeerent on the miata so the intake and exhaust cams get switched and I think there is some creative timing to do. Do a search for "miata cams" and you'll find many threads regarding this upgrade.
