Signal Lights
kat
Signal Lights
Post by kat »
Okay i have a question do you guys know if it is possible to take the passenger side signal light, flip it around and use it on the drivers side? At least the housing part of it?
Grants
BANNED Member
Post by Grants »
You talking about the ones on the front corners - under the headlights? If so the answer would be no.
kat
Post by kat »
Yes, not the side markers.
Grants
BANNED Member
Post by Grants »
Then no they won't change sides - they are even marked L and R. If you pull one out you can see how different they need to be - just one screw.
