Clutch is screwed or can it be adjusted?¿?
- MiltonCutie
Just wondering something. i have a 95 Mx-3 V6.. and i think that my clutch is loose somehow. In first gear i need to rev up to almost 3000rpm in order to not make my car hop .. is theer any way to adjust the clutch or what is going on.. any suggestions, please e-mail me @ missing_angel02@hotmail.com
any info would be greatly appreciated.. hate being looked at as a new driver
*-*Amanda*-*
- relisys_3200
- MiltonCutie
when i say hop i mean it doesnt feel like the first gear is catching. i have to rev the car in high rpm just for the car not to stale.. you know when you fist learn how to drive stick and you "hop" the car.. that what it dfoes when the rmp is not high enough. im thinking that the clutch is worn a bit and it can be adjusted from underneath the dash? i dunno..
- MiltonCutie
- MiltonCutie
- jschrauwen
could be a few things,
1) clutch is worn and slipping badly, do you find when driving a bit faster (higher revs) and you change gear, the revs climb higher and slip up before the car seems to "catch" and go?
2) Flywheel worn and possible scorched/warped. (bad) can cause jumping, destroy clutch and tranny possibly if its the cause.
3) drive axles worn out and spinning.
adjusting the clutch without physically inspecting is easy enough you can set the clutch pedal to where you want it to slip smoothly by bleeding any air in the clutch lines.
Also if by hopping you mean the car jerks alot could be bad mounts as well.
Do all your gears work fine??
goto local mazda dealer for a free inspection hey will tell everything wrong with it. then drive away, and see whats you think is important on the list.
Good Luck
Good Luck
I too am having the same problem.... I haven't checked the engine mounts although I highly doubt that its the problem.
I have been driving like this for a week now and it is slowly getting worse...my car even stalled as I turned into a parking lot today....which is wiered because I was in the process of downshifting to 2nd....
