What kind of times should I expect from a turboed KLDE?
Juans_93_MX3
I am just wondering
Say I buy a KLDE, turbo it, run it as max boost (14psi) and hit 250hp/250ft torque, what kind of times should I expect?
Infact, what cars should I be able to beat?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Juans_93_MX3
with that torque and hp your in low 13s high 12s
- mitmaks
you should be wasting Type R's etc. why Camaros, are you domestic hater lol
Juans_93_MX3
Are you serious?DavidOS wrote:with that torque and hp your in low 13s high 12s
With 250hp/250ft torque running on FWD I would be able to run low 13s or high 12s?
Sounds too good to be true
Would those times be possible on street tires? Or would I need some type of track tires?
EDIT:
It cant be possible
Rebel2k4 hits 14.23 @ 102.63 2.35 60'
on 8psi 260whp
http://www.mx-3.com/phpbb2/profile.php? ... ile&u=6802
Low 13s probably with upgraded suspension and track tires but not low 13s and high 12
Last edited by Juans_93_MX3 on April 10th, 2005, 2:03 pm, edited 5 times in total.
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Juans_93_MX3
I got love for domesticsmitmaks wrote:you should be wasting Type R's etc. why Camaros, are you domestic hater lol
Its just that I want to see how their face looks like when they get beat by a little MX3
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
exactly...
Bonestockkid (which I haven't seen around here in ages) pulled a 14.6 on an all-motor DE! Timpronk posted 14.385 on his all motor ZE last year.
Juans_93_MX3
A all motor DE? NA KLDE engine with no mods except exhaust, flywheel and some small other things?Nd4SpdSe wrote:exactly...
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
not street tires, or if they are street tires, make sure they are sticky.
You can pull off low 13s with a 250hp/250ftlb car.
if the ze with the exhaust done, flywheel, cai, bored tb, pulley can run between 14.1 -14.5 commonly(aproximatly 215hp and 170ftlbs,)
and you jump the the 250s the torque difference is retarded meaning your gonna increase pull similar to the original k8 to ze swap. Then take that diffrence and add it again and yes your into 13s. IF you cant get 13s with sticky rubber and your 250/250 in a little mx3 then you cant drive.
I would not doubt a good driver, good tires with that hp/tq in a mx3 can get 12s, if not theres always a 50 shot.
NA, intake and exaust, good suspension to reduce wheelhop (which i have an abundance of in my car), and thats itJuans_93_MX3 wrote:A all motor DE? NA KLDE engine with no mods except exhaust, flywheel and some small other things?Nd4SpdSe wrote:exactly...
thebonestockkid
good to know ive left some kind of a legacy and someone remembers eh? lol im still around bud, and i still have the car, i dont post cause i just cant be bothered usually hah i still to this day have no idea how i pulled that time off, i think it had a lot to do with really good track conditions thoNd4SpdSe wrote:exactly...
'97 Grenada black pearl Acura EL, JDM B18C 98spec ITR Swap. Power in Control full coilovers going in next spring. Not to mention a most unusual whining noise... coming soon.'92 Intense blue pearl Jeep YJ, OME lift, mudders, fun.
R.I.P.
'93 Clear white GS-DE ~14.648@92.98mph, 2.234 60ft. PARTING OUT PM ME.
