Are the 92 and 94 seats the same?
I have a 92 GS, if i were to get seats from a 94 RS would they fit my car or would i have to make adjustments? I''m talking about front and back seats
- papa roached
i know the front will bolt in but they are a slightly different style
- solo_ryder
I have a full 94 interior swap (minus dash) in my 92, its a long story but everything works better. I like the 92 front seats better, but the 94's are very comfy and have a good headrest. the back seats on the 94 are nicer, they dont have the wrap around look to them, they got a split in the middle, if you guys want any infor you can ask me
