canadian indeglow guages
- Hoodzy
do they exist
if so where at??
thanks!
if so where at??
thanks!
1995 Creek Mica Blue GS
Just get the US ones, after a day or 2 you will adapt, unless your inept.
They have MPH on the outside, KM/H on the inside. Opposite to what your used too.
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- Hoodzy
ahah thats just crazy talk now
jk!![Razz :P](./images/smilies/icon_razz.gif)
jk!
I have a pic of the guages on my Cardomain. U can adapt!
Preach on!JWMX3 wrote:i adapted
i prefer MPH anyways
I hate whiners
- Hoodzy
so with these whats the whole deal with having to shave them and all that fun stuff?
hey
yes they do http://www.speedhut.com
they list them as I have a set
![Image](http://memimage.cardomain.net/member_images/1/web/301000-301999/301960_34_full.jpg)
bad pic as I am at work only one on my car domain site
- jschrauwen
Carter, Your Speedhut gauge face is Swiss numerals on white face and no graphics - confirm? How do you like their quality and ease of install? What did the Cdn$ total come to and how long after ordering did it take?
![Werd :werd:](./images/smilies/werd.gif)
Special thanks to DJsMX-3 for clarifying some questions regarding the install process for me. My soldering job looked like a--, but at least I could wrap it up with electrical tape and hide everything behind the console pieces of course. Everything's working great so far. One thing I would mention though... in my case, I didn't have to sand the bottom of the needles down (I had no clearance problems at all just by using the screws on the panel already so no double-sided tape was used), BUT the butt end of the needles for the speedo and tach (not the ends that actually do the pointing - the other ends) were too long for me to fully pull the guage faces over so I ended up using a dremel tool to grind the butt ends down to make them flush with the black circular piece that the needle is mounted on. Just a heads up as you may have to do this with yours as well. Just take your time with it and everything should work out fine.
