Finished the second paint job on the car. Came out much better than before, but the first coat (sealer) had some shitty runs on the rear drivers 1/4 panel and a could spots on the door, but after spraying 3 coats base & 2 clear the orange peel & runs from the first sealer coat were almost nonexistent.
Still gotta sand the clear smooth but it will be way easier than the last paintjob in the titanium metallic color.
Car looks a bit goofy. Didn't have time to sand/spray the front bumper and the weather SUCKED the past couple days, too humid / rainy to spray the sunroof, door handles, mirrors & spoiler so I just sprayed them with primer for the time being.
Sorry if the pics look like the camera was dirty. It was SO FARKIN HUMID outside when I took them so the camera lense must have fogged up:
![Image](http://www.projectmazda.com/host/noblegreen/newfront.jpg)
![Image](http://www.projectmazda.com/host/noblegreen/newrear.jpg)
![Image](http://www.projectmazda.com/host/noblegreen/newside.jpg)
![Image](http://www.projectmazda.com/host/noblegreen/newside2.jpg)
![Image](http://www.projectmazda.com/host/noblegreen/fuba3.jpg)
![Image](http://www.projectmazda.com/host/noblegreen/shittydoorjambs.jpg)
![Image](http://www.projectmazda.com/host/noblegreen/hazeonpaint.jpg)
This is what happens when you put shrouding over top of the car after 6 hours of dry time. I pulled the plastic off an hour later to find it messed up the clearcoat a bit. Luckily its so light that I can take some car polish & remove the haze easily. You can see the orange peel on the right of the pic....not too bad at all.
Pics I originally posted can be seen here:
