$800 KLZE parts/project car
I am posting this on here again before I clean it up and throw it on ebay. Anyways like the title says the whole car is for sale NO PART OUT EVER . The car has 196000 on the chassis which is actually pretty solid, 15,000 miles on the ZE, it has ACT MX-6 clutch, Pheno spacers, NGK wires, New plugs, New radiator, Mounts replaced at swap, Tranny has 1200 miles on fresh rebuild, Short shifter, SS clutch line. Car is not running right now the battery died and I have yet to replace it, It was run 3 months ago around the block. I can't drive it due to the lame emissions laws here in So Cal. I just want to hook up a fellow mxer to at least use the motor and tranny as they are both in good shape. The body needs help and the interior is mostly stripped as I was going to weld a cage and turn this into a drag car but I got engaged and my fiancee doesn't want me to kill myself. Now this also comes with a set of MX-3 Stainless steel pedals, triple gauge pod, 92 mazda shop manual and the stripped AC condenser/compressor if you want it. Thanks everyone.
Shawn F
Shawn F
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
- SE-Man
What do you mean the body needs help? Is it drivable? Where exactly in SoCal do you live? If you have any pics please send them to WarMachinex0@hotmail.com
It needs a new passenger side front quarter panel, Minor dents and dings besides that, it is driveable it just needs a battery. I live about 30 minutes outside of San Diego. I will try to get ahold of a Digi Cam in the next week.
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Just a side note it does have a custom 2.5" catback, not to exagerate but it is the best sounding exhaust I have EVER heard with this motor, oh and it NEEDS paint.
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
