A forum for MX-West Car Club Related Topics. MX-West has two Chapters;, the original is in Vancouver, British Columbia, and the second is in Calgary, Alberta.
pull your plug wires one at a time and see if there is any moisture or oil in the chamber. if there is than your gasket is leaking. a temp fix is to blow the moisture out of the chamber with air, make sure to put a rag or something over the whole so you dont get all greased up. if that doesnt work check your spark plugs. I had the same problems and I replaced the plugs and got the moisture out of the chambers and it fixed the problem. this is only a temp fix for the larger problem of the leaking gasket so be aware.
thanks for the reply. Yes I do have oil in the plug well of cylinder 5 since my rear valve cover gasket is leaking. I have cleaned out the oil and it seems to be running much better but the problem is there very occasionally. Also I pulled codes 2,3, 10 and 15. Not sure if these mean anything in terms of the problem?
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
