Steering wheel play? how much is bad?
Typhoonk
Post by Typhoonk »
Was driving down a fairly straight road. I noticed that I could keep my car straight, but still move my steering wheel about an inch and a bit either way without it affecting my straight line. This feels like too much......
Is there a way to tighten it up or adjust it?
also sometimes when I take a slight right turn then a slight left turn, there is a spot that it feels like it sticks a bit when going from right to left?
PM for info
happyclown
Post by happyclown »
i've sorta noticed the same thing in my past few cars... but i always thought it was alighment or my pump was low on fluid or cold (i noticed it in dead winter)... i dont know of any fixes or any thing, nor have i even had the chance to invistigate it more ...
1993 RS Teal
OsoSlo z28
Post by OsoSlo z28 »
check in the engine bay at the steering linkage. check to see if there's a rag joint. if there is, that's probably you're problem.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
neutral
Post by neutral »
Another cause could be worn tie rod ends-at least for the loose play. At their worst, as they wear out, a car can really lose previously responsive steering. The process can be so gradual as to not notice it over time.
Image -Jim
