K8 turboing
K8 turboing
I`m just about to buy a turbo of ebay, and I just wanted to get some input on the size of it.
It`s a Garrett T3 .42/.48 AR, would this be big enough on a stock K8?
Gonna push a maximum of 7 psi.
I got about 24 hours to decide ($200)
nope-mx3
nope-mx3
- babyblueMX3
what trim is the compressor and how much boost do you want to run..if you give me those details I could try to calculate with the compressor map to see if it should go well. You want better top end or low end ?
RIP 400whp ZE-T MX-3
It`s one like this:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33742
Doesnt say a lot actually.
I`m not gonna run more than 7psi as I got stock internals.
low end or high end, hmm, difficult question, I want better acceleration, as I dont drive fast, but I like to accelerate
nope-mx3
nope-mx3
- babyblueMX3
we can't really tell you if it'll suit your needs since it doesn't say much on the add...but most t3's will be good for the k8nope-mx3 wrote:It`s one like this:
nope-mx3
I bought it atleast
now, I`m just trying to figure out the rest I need.
1. 8:1 or 10:1 fmu? (OBX 8:1 is $99 on ebay)
2. waldbro 190lph pump (is it a specific partnumber, or do they all fit?)
3. klde 220cc injectors (are these needed?)
4. IC
5. Bov
6. piping
7. management unit? (is this necessary, if so, wich should I get?)
8. a/f ratio gauge, boost gauge, oil pressure gauge
Anyone have any of this for sale?
nope-mx3
4. IC
5. Bov
6. piping
nope-mx3
- babyblueMX3
1. get a cartech 2025..it is adjustable just by turing a knob. you don't have to swap disc lie the Voretch's to change the rising rate..I'll have one for sale as soon as I intall my Megasquirt.nope-mx3 wrote:I bought it atleast
4. IC
5. Bov
6. piping
nope-mx3
2.get the 255lph HP..same price just better
3.I'll have them too for sale soon
7.what management unit? are you talking about a fmu.if so then I answered in number 1
Excellent, I`ll probably buy the cartech & the injectors.
The management I was thinking of, was something like an Apexi safc.
But I guess I wouldn`t need the cartech then.
Is there any specific walbro 255lph pump I should get, or are the ones on ebay (for random vehicles) just fine to install?
I`m just a bit unsure if I`ll be able to get the fuelpressure low enough when idle and slow driving (no boost).
I dont want to run too rich when it`s not needed
nope-mx3
nope-mx3
- babyblueMX3
S-AFC doesn't work with our ecu at WOT so it's useless...I ran my 255lph (hi pressure) on my ze n/a without a problem..
You want the pump for a mx-6/probe...it'll fit don't worry..
I was thinking of a Unichip by Dastek.
This can manage extra injectors, turbo-boost, ignition etc etc.
I got a real good price on this installed and mapped on a rolling dyno.
Just thought that this would be better than a mechanical fmu
nope-mx3
nope-mx3
- babyblueMX3
unichip by Dastek? what's is that..never heard of it
unichip does work great.... but!! its from Australia i believe and they tune it for your car and you can chagne it yourself last i checked...
ps. the last i checked was over a year ago
Now I got some parts atleast:
turbo, IC, boostgauge, afr gauge.
I`m lacking 2 injectors to mount on the intake (wich is activated on boost),
fmu and piping.
Anything else I should (must) get?
I`m not sure if I need a bigger walbro pump yet.
nope-mx3
fmu and piping.
nope-mx3
