Im not a 100% sure what those are called, Headlight covers, Eyebrows?
Anyhow, where would i be able to purchase those?
any idea?
Thank you in advance
-M
Where would i find Eyebrows?
- Princess*Precidia
Yes - eyebrows. I remember seeing them on ebay but there doesn't seem to be any at the moment. Maybe you could keep an eye out there if nobody else knows where to source them.
Good luck and welcome to the board!
Acamori
fx-designs has them. $35 cdn you might be able to find them elsewhere, though i'm not sure where.
- Princess*Precidia
- jschrauwen
psituning.ca
