the other day i noticed a grinding sound from the left rear, so i took a quick peek at the wheel. i noticed that the rotor was rusty as though the brake pad hadn't touched it! i took off the wheel and found that the outside pad wa pretty much untouched, but the inside pad was completely worn away, and some nice grooves cut into my rotor
i changed my brake pads maybe 3 wks ago or so, and i would guess that all this time the inner pad has been in constant contact with the rotor, while the outter one hasn't been doing anything.
can someone tell me what i did wrong and how to fix this problem??
this is for non ABS, disc brakes.
thanks guys
