klze water pump
klze water pump
KLZE water pump anyone know were I could get one for a reasonable price.
- papa roached
the parts store, same pump as on the MX-3 1.8 and the Probe/MX-6/626 2.5L
- babyblueMX3
not all pumps. I had to order 3 different ones so I can find wich one fits
some have different pulley inner diameter hole. IIRc some are 16 and other 32 mm. the offset is different on some too.
Best thing would be to give your old pump to the part store and ask them to search for the exact same in the mx-6. that's what I did and worked fine
RIP 400whp ZE-T MX-3
I have 2 used pumps....15 shipped if you want one, both work fine
DONATE TO MX-3.COM
DONATE TO MX-3.COM
I have a KL-ZE sitting in my garage, I replaced it cause of a serious knock in the back head. I never really found the problem, but I'm parting the engine out, unless someone want's to take it off my hands for 100 bucks. write me back at jasonx@stripnyne.com
