how much hp gains are we looking at for those thermal insulators i see advertised a lot at the top of the screen? OR would it be safe to say that thermal insulators are just a preventive measure in order that you don't lose hp due to excessive heat, and won't necessarily give you any hp, but maybe just restore some that you've lost throughout the life of the car?
also, the MS engine mounts... i read that they will give you an extra 2 hp or so... is this accurate?
couple hp questions
couple hp questions
1992 GS/RS Mutant Automatic
It keeps your intake manifold from getting too hot. So when you first turn on the car, a car with phenolic spacers won't make any more power than a stock engine. However, once your car heats up, the intake manifold on our cars gets crazy hot, robbing power. Phenolics cut the temperature some to regain a few HP that you loose from a hot manifold.
