Its a custom manifold(aka stock manifold), has a mitsubishi t25 flange on it...70$....takes it
he is really getting rid of the whole setup minus the turbo, and downpipe. So basically everything you see is for sale as well, hard pipes - etc.. name your price. he ran the stup wiht the 1.8 sohc ecu and it kept the fuel perfect. so that is also up for grabs.
this is a picture of it on a mx3..
interested! got any pics of what the bottom looks like, I.e what flange will I need to make the down pipe. also, does that flange for the t-25 mitsu fit any other turbo's? Pm me
Last edited by papa roached on February 15th, 2005, 9:53 pm, edited 2 times in total.
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
come on people , if i still had my RS i would be all over this
