Interior Lighting
Posted: February 12th, 2005, 11:32 pm
by Bling Bling
Depending which day of the week it is, my interior lights will not come on when I open the door, this includes the light by the ignition switch. Areas to look?
Posted: February 12th, 2005, 11:37 pm
by mxmaz
I'd say you need new door pins. Same thing happened with mine.
Posted: February 13th, 2005, 12:43 am
by jschrauwen
Spring loaded switch inside lower rear part of front door openning. Subject to gumming up and getting sticky over time. A little cleaning and lube and your back in business. Shouldn't need a new switch unless it's broken. Ignition switch light also tied into same circuit.
Posted: February 13th, 2005, 1:46 pm
by 93SOHC
mine does this as well, but if I just wiggle the pin on the door jam a bit it turns on. I deal with it for now, but when my interior gets redone, im gonna pull it out and clean all the contacts up real good. It works great, I did it before on my 94scort and no problems afterwards
