Interior Lighting
Bling Bling
Interior Lighting
Post by Bling Bling »
Depending which day of the week it is, my interior lights will not come on when I open the door, this includes the light by the ignition switch. Areas to look?
Stacy Whitrick
MX-West Calgary
http://www.cardomain.com/ride/1335558 UPDATED June 6,07
94 GS, Green Envy Pearl QUESTION: Does my car fit the RICE category?
mxmaz
Post by mxmaz »
I'd say you need new door pins. Same thing happened with mine.
jschrauwen
Post by jschrauwen »
Spring loaded switch inside lower rear part of front door openning. Subject to gumming up and getting sticky over time. A little cleaning and lube and your back in business. Shouldn't need a new switch unless it's broken. Ignition switch light also tied into same circuit.
93SOHC
Post by 93SOHC »
mine does this as well, but if I just wiggle the pin on the door jam a bit it turns on. I deal with it for now, but when my interior gets redone, im gonna pull it out and clean all the contacts up real good. It works great, I did it before on my 94scort and no problems afterwards
