Have a 93 Euro spec V6 Mx3 .. fitted KFZE Engine and ECU from 92 MX6 , kept my original Wiring loom leaving the EGR bits disconnected ... My Question is are the JDM Mx6 ECU's compatible with the Euro spec Looms ?
Tried to start the car but am getting no spark , Everything else seems ok . Tested Plugs , Leads, Disty , ECU ,Fuses and relays all good ... Starting to think there's a break in the loom somewhere .. has anyone had similar experiences ? Thanks
KFZE in European Mx
In late '93/early '94 the distributor changed, and the wiring of the 3 pin connector is different. This may be your problem, if you changed distributor. If you're still using the K8 distributor, it won't be an issue.
Maybe the KFZE ECU is defective. Try the K8 ECU, just to see if the engine will start.
Eureka
Finally figured it out ... Had an earth problem which burned out some wires .. Hence no spark . Replaced damaged harness and fixed ground problem and guess what .... it fired first tip of the key !
.. have fitted a Xedos 9 intake manifold ( Curved neck ) inc throttle body and the car seem to run fine ..
