If you had a ZE swap I Need YOUR HELP
Posted: January 31st, 2005, 12:05 pm
by PWRD_BY_HKS
Okay well i already ordered my motor and computer but my sponsor (HDS) has never done the swap i got a full intructional of the mx-3 links but what noone seems to mention is what
clutch they used and if the tranny from kl8 fits also if anyone could please tell me where the call numbers on the ZE are that be great.
Mx-3 Kid (El Paso,Tx)
Posted: January 31st, 2005, 2:44 pm
by XxantwawnxX
The k8 tranny fits. i used some perfomance clutch i got off ebay..worked fine
You can also use an mx6, probe gt, or 626 manual tranny.(v6 of course)
im not sure what u mean by call numbers, but the codes and shiz are on the back of the valve covers (dont need to remove anything to see them..maybe some dirt) and the have codes stamped on the cams. forget what there suppose to say : P.
Posted: February 1st, 2005, 1:59 am
by hgallegos915
woah woah are yo0u in el paso? email me! also in el paso..
hgallegos915@msn.com
THANKS For The Comments
Posted: February 2nd, 2005, 11:38 am
by PWRD_BY_HKS
What i meant by what clutch to use was off of the 1.8 or the 2.5 is there a difference
MX-3 KID Of El Paso Tx
Posted: February 2nd, 2005, 12:06 pm
by papa roached
the 1.8L clutch is 10mm smaller thanl the 2.5L clutch, the 2.5L clutch will fit on the K8 flywheel
Posted: February 2nd, 2005, 3:39 pm
by Dali
so any clutch kit from a 2.5 (mx6-probe) will fit into the stock mx3 tranny housing. so what would be better, getting a aftermarket clutch for the mx3 or the same clutch for the 6 or probe?
Posted: February 2nd, 2005, 4:06 pm
by Gro Harlem
YES! the clutch interchanges with the 626, probe, mx3, mx6..all this info is in the FAQ.
If you want a slightly bigger clutch, get the probe one. Its up to you. my mx3 ACT is plenty for my setup.
Posted: February 2nd, 2005, 6:12 pm
by Juans_93_MX3
I hope you dont have a automatic though
A ATX from the 1.8L cant handle all the torque
Posted: February 2nd, 2005, 6:29 pm
by dewthis
Don't skimp on the clutch, you might want to up the power down the road(cams,N2o). Be sure to inspect the mounts, poly fill if necessary might wanna go mazdaspeed. These are some of the things I'm going through now with cams and all.
Posted: February 4th, 2005, 11:06 am
by PWRD_BY_HKS
Thanks 4 all the help i already ordered a 6 puck clutch for the mx-6 thanks
Mx3 Kid (El Paso, Tx)
Posted: February 4th, 2005, 11:07 am
by Custommx3
Read the Faq, all this info is in there.
