If you had a ZE swap I Need YOUR HELP
PWRD_BY_HKS
Post by PWRD_BY_HKS »
Okay well i already ordered my motor and computer but my sponsor (HDS) has never done the swap i got a full intructional of the mx-3 links but what noone seems to mention is what clutch they used and if the tranny from kl8 fits also if anyone could please tell me where the call numbers on the ZE are that be great.
Mx-3 Kid (El Paso,Tx) :lol:
jdmx-3 KID OF THE Image
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
XxantwawnxX
Post by XxantwawnxX »
The k8 tranny fits. i used some perfomance clutch i got off ebay..worked fine
You can also use an mx6, probe gt, or 626 manual tranny.(v6 of course)
im not sure what u mean by call numbers, but the codes and shiz are on the back of the valve covers (dont need to remove anything to see them..maybe some dirt) and the have codes stamped on the cams. forget what there suppose to say : P.
hgallegos915
Post by hgallegos915 »
woah woah are yo0u in el paso? email me! also in el paso..
hgallegos915@msn.com
-hec
PWRD_BY_HKS
THANKS For The Comments
What i meant by what clutch to use was off of the 1.8 or the 2.5 is there a difference
MX-3 KID Of El Paso Tx
VICTORIA RACING
papa roached
Post by papa roached »
the 1.8L clutch is 10mm smaller thanl the 2.5L clutch, the 2.5L clutch will fit on the K8 flywheel
Dali
Post by Dali »
so any clutch kit from a 2.5 (mx6-probe) will fit into the stock mx3 tranny housing. so what would be better, getting a aftermarket clutch for the mx3 or the same clutch for the 6 or probe?
Gro Harlem
Post by Gro Harlem »
YES! the clutch interchanges with the 626, probe, mx3, mx6..all this info is in the FAQ.
If you want a slightly bigger clutch, get the probe one. Its up to you. my mx3 ACT is plenty for my setup.
DONATE TO MX-3.COM
Juans_93_MX3
Post by Juans_93_MX3 »
I hope you dont have a automatic though
A ATX from the 1.8L cant handle all the torque
2008 Mazda 3
1993 MX3 GS
dewthis
Post by dewthis »
Don't skimp on the clutch, you might want to up the power down the road(cams,N2o). Be sure to inspect the mounts, poly fill if necessary might wanna go mazdaspeed. These are some of the things I'm going through now with cams and all.
65 shot > V8
PWRD_BY_HKS
Thanks 4 all the help i already ordered a 6 puck clutch for the mx-6 thanks
Mx3 Kid (El Paso, Tx)
VICTORIA RACING
Custommx3
Site Administrator
Post by Custommx3 »
Read the Faq, all this info is in there.
