Bigger Fuel Pump For 1.8L
lilg19utk
Post by lilg19utk »
Does anyone out there know if the Walbro 255 will work for a 1.8. Or if there is anything out there that is just as good please let me know. Thanks
Talon_66
Post by Talon_66 »
Yes it will work, why wouldnt it?
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
lilg19utk
Post by lilg19utk »
Well i wasn't sure because i can't find a part number for it or where I can get one
lakersfan1
Post by lakersfan1 »
The stock pump will supply a 200HP engine with enough fuel, so what're you going to do that's going to require a 250LPH pump?
papa roached
Post by papa roached »
giggle gas?
lilg19utk
Post by lilg19utk »
Planning on dropping in a turbo.
