Bunch of weirdness...engine heat related
I'm finally the proud owner of a 96 Mazda MX-3...and a new member of your forums. Whoo!
I bought this car used obviously...and it seems like the person I bought it from hasn't done a thing to it...in other words it's pretty much factory right down to the kick-butt factory Mazda tape deck! LOL!
It's a V6 auto tranny too...
Anyways...after I'd say 6 months of zero problems (previous owner kept it in uncanny/immaculate shape) I'm having some very bizarre problems as of recent.
I took it in for an oil change, commence problems. When I started the car to warm it up (cold weather) after say 2-3 mins, the RPMs started reving themselves up...after a quick run in reverse and drive...it stopped. While driving, the tempurature got really close to the hot marker, pulled over, stopped the engine...opened up the hood...found there was NO antifreze! So filled it up...car ran smooth as silk for 2 weeks...NO antifreeze again!
Doesn't seem like I have a leak..the ground is pretty dry where I park my car everyday...what could be burning up my antifreeze?
On top of that...hot air decides when it wants to work...it'll be hot for awhile...then the heat dies completely out....cold air blows in after....brrrrrr. It seems like it only does this when the engine heat is high...I don't understand what could be going on...and it seemed to start RIGHT after I got my oil changed.
Any clues?? I'm taking it in for a tune up at a Mazda dealership within the week.
EDIT: Oh ya...forgot to mention...when I actually drive....reving the motor and such....the heat dies down....what gives!?
- XxantwawnxX
U might have a really bad headgasket leak..and ur burning all ur coolant? Do u get white smoek out ur exhaust (more than whats common)
- papa roached
might be bad water pump but also sound like the issue i had, i had a leak in my radiator that would only leak when the revs were up but not at idle
- mitmaks
ya definitely check your radiator and water pump, if those are good then its BAD, you got major head gasket leak, also check your oil, what color is it, is it milky?
- neutral
Need to find the leak. Running smooth as silk seems to indicate there is not a likely headgasket prob. Top up the coolant, spread newspaper under the engine bay and run to operating temp. If nothing is found, drive a brisk 10-15 minutes and park over the newspaper. Check for signs of a leak right away and you should see signs of the source.
The heater issues are likely all related to changes in your coolant levels because the source of heat is the circulating coolant. When levels are too low, the heater core has an insufficient & intermittent heat source.
- papa roached
also run it up to 2000-3000 RPM in neautral over the paper, if it was like mine you wont see it after driving then stoping
Re: Bunch of weirdness...engine heat related
FYI - You check the coolant at the radiator cap on the passenger side of the car when the car is cold.. Sounds like you're checking the overflow resivoir which doesn't tell you how much coolant is actuall y in the cooling system.keeko_ca1 wrote:...opened up the hood...found there was NO antifreze! So filled it up...car ran smooth as silk for 2 weeks...NO antifreeze again!
Get the two caps pressure tested, or just replace them. You can lose coolant imperceptably through a cap, as it will only come out when the engine is hot, and it will evaporate at the point of the leak. Then, when the engine cools and it should pull back fluid from the overflow tank, the leaking cap loses the vacuum, so the pull-back doesn't happen. So, as Lakersfan said, the overflow looks full, and the system is low.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
- 93-Spec-Edn
i agree. i had mine pressure tested and my fill cap was leaking. I lost only a tad bit of coolant in the recovery tank, not much. If it was your head gasket your car would idle rough and be slow and also your engine would sound off (kinda louder).IanL wrote:Get the two caps pressure tested, or just replace them. You can lose coolant imperceptably through a cap, as it will only come out when the engine is hot, and it will evaporate at the point of the leak. Then, when the engine cools and it should pull back fluid from the overflow tank, the leaking cap loses the vacuum, so the pull-back doesn't happen. So, as Lakersfan said, the overflow looks full, and the system is low.
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
- jschrauwen
I'm leaning toward low coolant level also, as to why, the rest of the thread have made some good suggestions. The fluctuating idle speed is indicative of severe air locks in the system. Temperature sensor hits an air pocket and sends incorrect info to CPU causing the idle to fluctuate. System needs to be purged of air. Experienced similar problem before which later turned into a complete water pump failure. Milky coloured oil would indicate faulty head gasket.
