Getting my ZE to pass emissions
Well three tests later I finally got my ZE to pass massachusetts emissions. I failed the 1st time because I had a bad rotor. It was loose on the distributor shaft and chewed up the inside of my dist. cap. I failed for Nox, CO & HC. 2nd go round I passed HC & CO but failed Nox. Limit was 2.5 I got 3.47. So this last time I added a gallon of coleman camp stove fuel to ~1/3 tank of gas. My HC & CO dropped ~30% and my Nox went from 3.47 to 2.37.
In short add a gallon of Coleman Camp stove fuel to a 1/3 tank of gas and you will pass emissions.
91 Eagle Talon Tsi AWD *RIP*
had my car registered since august 2003 and i've still yet to get an emissions letter.
we are supposed to check it every 2 years here in MD. Maybe they forgot about my car![Smile :)](./images/smilies/icon_smile.gif)
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Re: Getting my ZE to pass emissions
That's useful to know, but do you know what's in Coleman's? Its not something one could get in UK by name.TsiMiata wrote:In short add a gallon of Coleman Camp stove fuel to a 1/3 tank of gas and you will pass emissions.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
Where did yo hear of this trick?
I have e-test due in Feb
What octane gas did you have in the tank when you put the coleman fuel in? Did you get tested as a stock K8 or did you go under a "modified" (hotrod as we call is here in Ontario, CanadA) class?
Sorry for all the questions, it's just that I' wanna give this a try this or next week.
Wondering why you want to try thisNd4SpdSe wrote: "modified" (hotrod as we call is here in Ontario, CanadA) class?
![Question :?:](./images/smilies/icon_question.gif)
http://www.mx-3.com/phpbb2/viewtopic.ph ... ht=ontario
Ontario ROCKS!!!
to play it safe, take as many precautions as possible, because of this:
http://www.mx-3.com/phpbb2/viewtopic.ph ... highlight=
BTW, TSIMiata...how long did you drive with the coleman fuel in your tank before you went for your test
