who has put a 2.5 auto tranny in
Dali
Post by Dali »
who has put a 2.5 tranny into their car from a probe or 6, did anything have to be changed, ive searched and asked for help but keep getting different stories, did the auto tranny unit need to be changed, any rewiring, thanks, im dropping in the klze motor with tranny, kl36 ecu, and might get a kl32 auto tranny control module but if i dont need it i dont want to spend another 100 buck.
1993 White gs klze.
greenstorm
Re: who has put a 2.5 auto tranny in
Post by greenstorm »
I am currently working on the same project as you, putting in a KLZE engine and the AT that came with it. I am now told that mounts dont line up, but im going to check that out and probably have my friend weld some crappy ones to hold it in. The wiring seems much different and it scares me.....so right now im just going with it and I'll have to see what happens. Keep in touch, maybe we can help each other out.
what kind of car IS that?
mykel78
Post by mykel78 »
Did either of you succeed?
If not broke - don't fix, modify. If broke - fix it right, and make it better.
Dali
Post by Dali »
nope, too impossible, switching to 5 speed :)
1993 White gs klze.
mykel78
Post by mykel78 »
are the mounts and control units different between the klze's tranny and the k8's tranny? what was so impossible?
Dali
Post by Dali »
none of the mounts lined up, differnt size mounts, plug in top was different with more wires, just seemed like too much trouble. not impossible but more work than i wanted, plus i was planning on doing the mtx swap so it wasnt worth it to me at the time.
1993 White gs klze.
Juans_93_MX3
Post by Juans_93_MX3 »
So I see the 2.5L Probe ATX that comes with the KLZE had problems mounting.
How about the 2.5L Probe MTX?
2008 Mazda 3
1993 MX3 GS
Return to “Transmissions”
