My 93 has no fluid drain plug that I'm aware of. Is there an easier way to changed the fluid without dropping the pan? (I recently did this for a filter change).
Can a drain plug be tapped into the pan somewhere? Is there something i am missing?
Also I was under the car today looking around and noticed a large flat allen headed bolt on the engine side of the tranny pan just about at the end of the pan toward the back of the car. Is this some type of drain plug?
Draining ATX fluid....
- mitmaks
Re: Draining ATX fluid....
yes that is drain plug
