Where to put ATF in manual transmission
i just replaced the cv joint and axelshaft on my 1994 4cyl mx3 and when i pulled the broke one out ATF poored out, was just wondering where is the place to put the ATF back in? i couldnt find it, sorry new to mx-3's any info would help a great deal thnx
2004 Nissan Xterra - Daily Driver
2003.5 Mazdaspeed Protege - Sold
1994 MX-3 RS - Selling
Searching for a new performance car to buy, cant decide.
http://www.sounddomain.com/id/omenmx3
Re: Where to put ATF in manual transmission
to refill your tranny, pull out the speedo gear on the top/back of the tranny.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Damien:<BR><STRONG>i just replaced the cv joint and axelshaft on my 1994 4cyl mx3 and when i pulled the broke one out ATF poored out, was just wondering where is the place to put the ATF back in? i couldnt find it, sorry new to mx-3's any info would help a great deal thnx</STRONG><HR></BLOCKQUOTE><P>u don't<BR>u put mtf back in <BR> ![Very Happy :D](./images/smilies/icon_biggrin.gif)
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
my car is a 5spd, why would there be ATF in there?<BR>should i put ATF back in it?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Damien:<BR><STRONG>my car is a 5spd, why would there be ATF in there?<BR>should i put ATF back in it?</STRONG><HR></BLOCKQUOTE><P>atf - auto tranny fulid<BR>Mtf - Manual tranny fulid
2004 RX-8 - Project
2004 RX-8 - Project
nono i know that but my car is manual, why would the tranny be full of ATF, i read its cause of tempature, but should i put mtf back in? or atf? any suggestions?
Some of the mazda vehicles use ATF even in manual transaxels (or so says chilton). It goes in the transmision as would regular mtf fluid. <BR>Check the color to make sure, but I'm pretty sure this is the case for you. I wouldn't recomend mixing the two.<P>Otherwise it might possibly be from the power stearing, some times people use ATF instead of power stearing fluid, although I don't know why.<P>good luck
tk1138<P>There's not really anything I want to say over and over.
atf is made for harder shifting environments, as for mtf check the book you may need gl-4 for brass synchro gears but i am not sure
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
Check the online shop manual on the MX-3.com homepage,it has a detailed procedure and fluid specs.
