Power Windows roll up slooooowwwwww
Ainu69
Post by Ainu69 »
I have no clue what causes this might need new door switchs but i don't think its the problem. basiclly my windows roll up ultra slow somtimes no problem but most of time i actully have to help the window up its kinda a pain in the rear.
anyone have this problem i have 1994 gs?
thanks chris
10-4
ZEmadman
Re: Power Windows roll up slooooowwwwww
Post by ZEmadman »
first check your battery voltage, if it's less then 12 it could cause the windows to go up slow. i know when mine went out a couple of months ago it caused the window to go up slow.
other then that i'd say it would the motor, not the switch itself... :shrug:
Ainu69
Post by Ainu69 »
well i just replaced my battery because my car died and would not start. so i know my battery is now good, yet the problem has been ever since i had it about 2 years now, i just can't figue it out
chris
10-4
Typhoonk
Post by Typhoonk »
Check the switch and make sure none of the contacts are dirty with white stuff on it, or loose. Try another replacement switch if you can find one.
Or to see if the motor is still good. Find the two wires that go to the actual motor. The + and -, then supply the power and ground and see how the motor goes.
Sounds like a bad ground connection, or the switch.
PM for info
Gro Harlem
Post by Gro Harlem »
grease the rails....makes worlds of difference.
DONATE TO MX-3.COM
perhapsadingo8yerbaby
Post by perhapsadingo8yerbaby »
:2thumbsup:
I had that problem but for me it was the switch. I replaced the driver side switch with the passenger side-style and it works way better. (wasnt as bad as you though) I guess it wasnt making good enough contact. I initially repalced the switch cause the internal plastic part that pushes/pulls the contacts snapped, so it wasnt working at all
<small>[ October 15, 2004, 07:48 AM: Message edited by: Nd4SpdSe ]</small>
xXdaveXx
Post by xXdaveXx »
damn im having this problem too! it started like a month ago :)
Zetgohan
Post by Zetgohan »
my problem was because the windows were left down so long and the stripping became dry but not cracked. I used some WD-40 on a cloth and rubbed in on the stripping (get inside it too).
I noticed it made a big difference
Gro Harlem
WD-40 won't last though, you want to use real lithium grease, the white stuff.
It'll make ur windows shoot up fast as hell.
DONATE TO MX-3.COM
thats a misconception of WD40, WD40 is actually a Water Displacer that in which it's formula was conceived on the 40th try (thank you tech tv and my brain for retaining useless information). WD40 is not a lubricant
adrenalin
Post by adrenalin »
my windows dont roll up at all! it just died on me all of a sudden.. one minute its working next ,its dead..
<small>[ October 31, 2004, 07:55 PM: Message edited by: adrenalin ]</small>
mitmaks
Post by mitmaks »
id get motors rebuilt or at least see if they are lubricated
mdavis
Post by mdavis »
The common solution is like Gro said.. greace the tracks. *Search*
GS-R SE
Fixin's
