93 4cyl no spark HELP
Help 93 MX (4 cyl)with no spark.....no tach movementor engine light while trying to start....fuses all check good, timing belt good....just cranks and cranks and cranks.....any help please
- Franko
Re: 93 4cyl no spark HELP
99% chance your coil is gone.. It is good you have a 93 because the coil is external, right next to the fuse box... You can have the coils resistance checked but I would say that is your problem. If it turns out to be your problem then when you buy a new one you might has well upgrade it at the same time.. i have one like this and I actually find it very good with a noticeable difference.
<img src="http://www.msdignition.com/images/pn8207-7.jpg" alt=" - " />
Blaster SS coil Part number:8207
Cheap, easy to put in and actually makes a difference.
