back from the track april 14
not a bad day , I still drove home so that is good.here's the time.<p>re.-.581<p>60ft-2.145<p>330ft-5.800<p>1/8et-8.718<p>1/4et-13.323<p>mph-103.70<p>that was with 10lbs tire pressure(too low), 39/25 nitrous shot at 15'C<p>so I think I can do better with a full tank of gas and the combo of good 60ft with 18psi tires because with 25psi the trap speed was 109mph
13.023 @ 105 mph
Re: back from the track april 14
ahh the beauty of nitrous
Good Job, Congrats!
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
Aaron, i know u've posted before but im curious what mods you have to ur klze to handle the nitrous? I would assume adjustable FPR, upgraded fuel pump, maybe larger injectors?? Also, what kind of features does ur nitrous kit have?? Thanks..
My Cardomain site
My Cardomain site
Ihave a adj. fpr + zfr6f11 plugs timing at 8* thats it. kit is a wet setup with a 39n2o/25 fuel The motor is getting more than enough fuel. I even ran the stock fuel pressure to lean out the shot. <p>p.s. don't run platnium plugs, it's bad<p>[ April 16, 2003: Message edited by: aaron the hic ]</p>
13.023 @ 105 mph
why it only melts the plug, thats not important ![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
the thing I love about the mazda motor is it repairs itself.<p>I melted the plug on #4 because the injector was bad and I had a platinum plugs in . the compression all around was 165 but #4 was 135 , I went to the track anyway thinking it was going to blow up anyway but it ran fine . then I checked it again on weds. to see how much damage had been caused and the #4 cylinder was back to 165 which is not good but will do .<p>In conclusion Nitrous fixes motors ![Very Happy :D](./images/smilies/icon_biggrin.gif)
13.023 @ 105 mph
aaron, you are on crack, lucky! but on crack
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
how aboot this. I was geting the bottle filled and the tech at P.I. turned the bottle upside down with 1200psi in it and the release blew.( the release was installed by the Tech.)He got 2 bad frost bite burns, one on his wrist and the other on his stomach. it did not look fun, when I left they had closed the store and he was lying on the floor in alot of pain.<p>the release was an nos for a blow down tube with a pressure disc which is supposed to be torqued but was not and caused the disc to fail prematurly.<p>the tech is lucky he is not blind because they do not wear any face/eye protection.
13.023 @ 105 mph
Oh god oww!! Liquid Nitrogen burns soooo bad and the wounds stay for a month. Oww. Aaron you got a kl31 ZE or a kl01 ZE? Thanks.
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Tech ehhh! I don't know if I would go that far as to call me a tech after that! Yeah I got some pretty bad burns from the nitrous and a couple of days off work too! I don't think it was the trq that caused it to blow because I already filled that bottle once before fine. When I turned it over I felt it all go to the bottom maybe causing a big blockage, causing the psi to rise and the cap to pop! They bought maskes and a cape for us now so hopefully this is safter for next time.<p>P.s. This isn't the first time this has happend actually it is the third. (first for me and first time someone got burned bad)<p>Later 1SICKMX6!
93 MX6 Black Plate "1SICKMX6"
I gotta say that im just glad your ok and that you are safe.
kl31. brandon get your company to buy a torque wrench and don't fill a bottle with that relief valve style unless you have torqued it yourself<p>I guess you guys lost that whole tank...wink...wink.
<p>I'm going to spank so dirty dsm *** !
13.023 @ 105 mph
