The perfect launch
The perfect launch
What is the perfect rpm to get a good launch with a GS. I launched once at 3000 and got a lot of wheel bounce (bad shocks I suppose) and that cost me a lot of time as once things settled the revs dropped to about 1500 before the car really started going. Then later I launched at 4000 and my tires spun for a second and I got a decent launch. I know the MX-3 has a terrible first gear, but is there any way to get a really good launch that can help make up for this shortcoming. <P>As a note I'm proud to say that (even though I lost because first gear sucks) once I got it into second I didn't lose an inch to my friend and his 200+hp JEEP Wrangler. Ended up only losing by a car length the second time.
Re: The perfect launch
Your launch depends a lot more on your tires as opposed to your rpm's Just really have to find a balance you like.<P>If you want it to stick better for a higher rpm dump you need a softer rubber or more sidewall..
-torp.
I don't own a Mazda.
I used to race my mx-3 alot about 2 summers ago back when I just got it. I had brand new BFG Touring TA 205/55/15's. The clutch was in decent shape and the suspension seemed pretty good. I couldn't chirp the tires shifting to 2nd but the clutch had decent bite to it. <P>So the best way to launch was: hold it at 5000 rpm and drop the clutch. (yes I know that was very very bad but I did it anyway). If I dropped it at 3000 rpm it would just bog, same with 4000 rpm. When I dropped it at 5000 rpm I would leave about 10 feet of rubber then I would have traction. I think when all the smoke was clear and I had traction the tach would be at about 3000-4000rpm already so first gear would go pretty quick. <P>I hope that helps.
I disagre with most of you wheel spin will cost ypu 60' times (racing is hard on your clutch) so bring the RPM's up to 3-4 then let out the clutch as fast as you can with out spining the tires then floor it
Thanks for the suggestions, my clutch is in great shape (clutch master's stage 2) and can grab hard when I race. My tires are Dayton Daytona HR which have strong sidewall and great traction.
Heh my clutch is abit on the toast side right now need to finds the time to drop a new one in i can still get it to spin the tires though.
-torp.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by white fish:<BR><STRONG>I disagre with most of you wheel spin will cost ypu 60' times (racing is hard on your clutch) so bring the RPM's up to 3-4 then let out the clutch as fast as you can with out spining the tires then floor it</STRONG><HR></BLOCKQUOTE><P><BR>Have you ever raced? Mild spinning is the fastest launch with street tires and FWD.
-93 MR2
#129 E-stock
#129 E-stock
I have recently Put in a KL-ZE in my MX and if i launch at 3-4,000 RPM then i will spin first, second and i will catch Third. I would never launch that high. I think the best way to launch is when u limit the spinning of your tire. Usually i will launch at 1,500 and try to chirp the tires so u actually dont do a big burnout and sit in one spot. I have a stage one clutch and a Fidanza flywheel....With my old 1.8 i launched at 2,500...
2.5 KL-ZE, BBS rims, I the front i have to falkin Azenis, Intrax Springs, CM Stage 1 clutch, and Fidanza flywheel, Pacesetter short shifter, Tociko Blue Struts, Sparco Steering Wheel, Yellow Top Battery
Alpine Type R Subs 10's, Alpine 2 Channel Amp, Alpine 4 channel
Amp, Alpine Alarm,Alpine Headunit
14.8 @ 94.2(with vaccume lick)
haha yea I have raced a fair bit and read lots or articals on racing and spinning cost you 60' times <P>either your spinning or your moving and you want to move down the track not sit at the line then move down track right
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by white fish:<BR><STRONG>haha yea I have raced a fair bit and read lots or articals on racing and spinning cost you 60' times <P>either your spinning or your moving and you want to move down the track not sit at the line then move down track right</STRONG><HR></BLOCKQUOTE><P><BR>I run 2.2 sec 60' times on street tires without the help of a good clutch or VHT. Do whatever you want. I'll stick to getting out of the hole quicker than you.
-93 MR2
#129 E-stock
#129 E-stock
I am willing to try this spinning techniqe i usually launch at 3500 to 4000 rpm and i launch like a snail what would ba a good rpm to launch at for a mild spin launch. protege sts?
You can just call me the originator
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by mrprecidia:<BR><STRONG>I am willing to try this spinning techniqe i usually launch at 3500 to 4000 rpm and i launch like a snail what would ba a good rpm to launch at for a mild spin launch. protege sts?</STRONG><HR></BLOCKQUOTE><P>Practice...as has been said before in this thread, there is no "ideal" number. You gotta take a look at a lot of different things. Tires, surface, clutch, power....<P>I launch at about 3500 rpm, but with the BP, thats damn near peak torque.
-93 MR2
#129 E-stock
#129 E-stock
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ProtegeSTS:<BR><STRONG><P><BR>I run 2.2 sec 60' times on street tires without the help of a good clutch or VHT. Do whatever you want. I'll stick to getting out of the hole quicker than you.</STRONG><HR></BLOCKQUOTE><P><BR>HAHA whatever buddy
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by white fish:<BR><STRONG><P><BR>HAHA whatever buddy</STRONG><HR></BLOCKQUOTE><P>And your 60's are?
-93 MR2
#129 E-stock
#129 E-stock
2.2 , 2.3 , 2.4 in that area but when my tires are spinning around 2.7
