Top speed test day!!!!!!!!!!!
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
Mr Mx
Post by Mr Mx »
Hi all I might be taking me mx to a airfield for a top speed test day on Sunday, might onl watch or should I take my car up!!!!!!!!!!
OsoSlo z28
Re: Top speed test day!!!!!!!!!!!
Post by OsoSlo z28 »
go for it....i know i would
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Mr Mx
Post by Mr Mx »
I think I probally will. Only running a PRM intake and different back box so nearly standard. But I guess it`s not all about beating other people it`s just wot can ya do!!!!!!
Bri94GS
Post by Bri94GS »
You should run your car stock, then run it with the mods to see what you improved on, and what you need to improve on...just my $0.02
~Bri - Morph860@aol.com
'94 MX-3 GS (FOR SALE!)
'04 Mazda 3s 5-door
zoom-zoom
KWK MX3
Post by KWK MX3 »
Things tend to get real squirly at those speeds. The car isnt meant for top speed.<BR>Wear your seat belt and hold on buddy,<BR>oh and have fun
KWK MX3
DriversClub
Post by DriversClub »
Took my ZE up to 150mph under its own power I think there has to be some kind of governor or something that stops it from going over 150. I was at 150mph at right around 7k rpm. my rev limit is set to 7.5?<BR>Anyways I did it out on the track and with this ground control sus. and koni struts thing felt tight not squirly...good luck
Mr Mx
Post by Mr Mx »
Unfortunatly i did`nt make it to the test day. Weather too crappy high winds and heavy rain!!!!! Did`nt see the point in going in weather like that. Oh well i might head off to a drag strip in the next week or 2!!!!!!!! Weather permitting
jkpgt96
Post by jkpgt96 »
Definatley, what kindof speed would you expect from a nearly std. 3??
Laser Red '96 GT-12:1-IBeams-10k RPM-EXT. OIL PUMP-COLT ONE-OFF CAMS-CUSTOM LONGTUBES-SHEETMETAL IM-BUILT HEADS-125 SHOT-PAR 3/4 GEARSETS-MFACTORY LSD-ETC..SHOULD BE A FUN RIDE..:thup:
http://www.cardomain.com/ride/542054
slowmx3
Post by slowmx3 »
DriversClub wrote:Took my ZE up to 150mph under its own power I think there has to be some kind of governor or something that stops it from going over 150. I was at 150mph at right around 7k rpm. my rev limit is set to 7.5?<BR>Anyways I did it out on the track and with this ground control sus. and koni struts thing felt tight not squirly...good luck
I don't see how that is possible because the gearing on the mx-3 trannys are so low. i am at redline at around 135MPH. Unless you changed gear ratios it won't work.
1992 mx-3, a couple mods, i'm still a n00b
---Don't try and church your car up, MX-3's aren't fast---
PATDIESEL
Post by PATDIESEL »
I agree 150 is imposible. I got 140 at 7.5gs in my ZE. after that wa,wa,wa,wa --> rev limiter
slowmx3
Post by slowmx3 »
PATDIESEL wrote:I agree 150 is imposible. I got 140 at 7.5gs in my ZE. after that wa,wa,wa,wa --> rev limiter
Thank you, it is NOT possible to go that fast with our transmissions in stock form. Sorry but i have to raise the BS flag on that one.
mitmaks
Post by mitmaks »
my k8 does 130. built up ze with mx-6 trans...150 maybe a possibility
PATDIESEL
Post by PATDIESEL »
True, I have a race in two weeks at a 2.5 mile track with a nearly 1 mile straight and hope to test that with my new LSD MX-6 trans... We'll see.
mx3mike1
topspeed
Post by mx3mike1 »
whats the yop speed on an mx
1996 mx3 gs - so long
1997 Talon Tsi Awd - 350whp ya I wish
mx3mike1
topspeed
Post by mx3mike1 »
mine does 150 km/h
Return to “Drag Strip/Track Racing”
