Nuthin against a fellow mxer, but what is this?? very unique thats for sure.. <p>[ July 30, 2003: Message edited by: DVH ]
[READ THE RULES, Do NOT bypass the language filter] SORRY BIG GUYS<p>[ July 31, 2003: Message edited by: DVH ]</p>
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Marlon: hes got chickens under there<hr></blockquote><p>you would think so.........hahaah<p>
lets hope he does, cause he is gonna give us all a bad name
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
I'm inclined (or declined as the case may be) to suspect that it is a work in progress pic, because if you look at the rear you can see he/she left an opening for the exhaust to go through, there is a muffler tip it's just not making it through. If they were leaving just the mesh, there would be no need to have that opening....on the other hand....the big APC on the hood suggests the owner may dig the look. The hood pins strike me as being in an odd location....at least compared to where I've seen them on other MX3's <p>[ July 31, 2003: Message edited by: Darren Hyderman ]</p>
Thats terrible! Even if he does plan on fiberglassing that hes going to go from a chicken coup to a snow plow in no time at all. That guy is a disgrace to the mx-3 community.
Mods:
Mods:
