Need a smoother ride...
MX-3 Money
Post by MX-3 Money »
Well I was just woundering what I could replace that would give me a better ride. I have replaced my struts with new ones and was expecting a better ride. So what else could I replace?
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
RoundTop
Re: Need a smoother ride...
Post by RoundTop »
springs and tires.
also check your tire pressure. it should be around 28-30psi. Overinflation will give you a harder ride.
low-rider rims will give you a harder ride.
some performance tires will, and springs are a good way to give yourself a better ride.
MX-3 Money
When you say springs, im assuming you mean stock springs. Cuz I know lovering springs give a harder ride.
Casino
Post by Casino »
a thick side wall tire will help.
however the mx-3 is a sport compact and as such it will have a somehwat harsher ride :shrug:
http://www.realtimeperformance.ca
03 miata, formally bottle fed 96 DOHC
schuttie2002
Post by schuttie2002 »
buy a buick
