crunching noise
mxmaz
crunching noise
Post by mxmaz »
When i go over bumps i hear a crunching noise and i can actually feel on the floor, like a knocking on my feet. Any suggestions?
mitmaks
Re: crunching noise
Post by mitmaks »
cv joints/axles, commmon problem on mx3s with age
mxmaz
Re: crunching noise
Post by mxmaz »
I kind of figured thats what it might be. Its just when i mentioned it to a local mechanic, he said that bad cv joints shouldnt make crunching noises on bumps, but just make knocking sounds while turning.
Thanks
mxmaz
Re: crunching noise
Post by mxmaz »
Had her checked out, got 2 cv joints and 2 outer tie rod ends are toast. So i had the tie rod ends done and i'm still getting the clunking noise. And i just replaced the ball joints as well. Mechanic said there is a worn swaybar bushing as well, would that be the likely cause of the clunking i can hear and feel on my feet when i go over bumps? or could the cv joints cause that as well?
<small>[ September 30, 2004, 08:36 PM: Message edited by: mxmaz ]</small>
yuuki
Re: crunching noise
Post by yuuki »
i dont have a crunching noise when going over speed bumps or turning, but when i drive for around half and hour or so i do have this crunching noise when i am braking sometimes that i kind of "just" hear and feel... if i'm going a high speed the crunches are faster "crunchcrunchcrunch" but as the car slows down the crunching slows down too "crunch crunch crunch"...
what could be the problem that i have? my braking isn't affected however when it is crunching i can ever so slightly feel the car rock back and forth while i am braking as it crunches... if i really wanted to i can apply more or less brake and it will almost stop the crunching... if i turn my music on i can't hear it, even when the music isn't loud
<small>[ September 30, 2004, 06:48 PM: Message edited by: yuuki ]</small>
Zetgohan
Re: crunching noise
Post by Zetgohan »
check your brake discs for scrapping or gouging and lean on each corner of your car (to see if you can hear the noise)
Grants
BANNED Member
Re: crunching noise
Post by Grants »
Check your brake discs, maybe they're warped.
jpwmx3
Re: crunching noise
Post by jpwmx3 »
It's a broken stabilizer link. ;)
